Old 7-Nov-2013, 6:50 PM   #5
Geek
It seems that the strong signal from WUNI may be causing interference. That would explain the difficulty with signals that should be easy to receive. To eliminate the problem you could try placing the antenna on the side of the house away from WUNI, using the house as a shield, or try a more directional antenna such as an XG43. You could keep the ant751 for the VHF channels.
Except that I'm able to receive much weaker signals. Also, when the antenna was mounted on the deck, I had far more blocking the aimed direction and virtually nothing blocking the WUNI signal and could get WBPX. Would have thought the interference would be far greater in that location.
This is why I'm so puzzled. Nothing makes logical sense.
WUNI was always LOS and always came in very strong (even being over 90 degrees off the alignment) And yet, WBPX came in weak, but usable with a NM of 30.2 and 2 edge reception. Now that the NM is 39.5, I can't get it at all. It is still listed at 2 edge, but with over 30' more height, it just seems odd I can't get it.
What is really puzzling is that I get (although it is marginal) WWDP at roughly -2.3 NM. Although that is on another band.
I'm hesitant to put up a larger antenna - we have strong winds and I don't like the idea of a large wind load.
RCA ANT751 and RCA TVPRAMP1R mounted on Gable End. Mast is roughly 7' over roof and antenna is just shy of 40' high. Current TVFool Report:
http://www.tvfool.com?option=com_wr...46ae65c2ffc82f
Geek is offline   Reply With Quote
