Old 7-Nov-2013, 6:38 PM   #4
Geek
Originally Posted by teleview View Post
Test reception without the , preamplifier , power injector , power supply.
That would be nice, but it isn't going to happen. Mostly because I can not get to the amp easily and there is no way I'd want to break up the sealant just to have to redo it all again. I have absolutely no reasonable expectation that such an action would have any positive results. My strongest station is only rated an 83%.
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To Clear Tuner , Do Double Rescan , www.wchstv.com/DoubleReScanAlert.pdf
Have already done that multiple times.
www.coaxseal.com , works better the silicone sealer.
Better at what? All external connections have rubber boots on them. I injected silicon into the rubber boots to completely seal the connections. This was all done months ago in a warm dry location. Never had any issues with the connections all summer. Even in driving rain.
RCA ANT751 and RCA TVPRAMP1R mounted on Gable End. Mast is roughly 7' over roof and antenna is just shy of 40' high. Current TVFool Report:
http://www.tvfool.com?option=com_wr...46ae65c2ffc82f
Geek is offline   Reply With Quote
