Old 7-Nov-2013, 3:47 PM   #2
Tower Guy
It seems that the strong signal from WUNI may be causing interference. That would explain the difficulty with signals that should be easy to receive. To eliminate the problem you could try placing the antenna on the side of the house away from WUNI, using the house as a shield, or try a more directional antenna such as an XG43. You could keep the ant751 for the VHF channels.
