Pratical and Useful Information.
Yes , to receive as many channels as possible to the South and North with 1 antenna aimed in 1 direction with no antenna rotation , install the CM5016.
As you stated , you think you can install the antenna at 10 to 15 feet above ground and miss the trees.
Meaning the main bulk of the tree limbs and leaves , and have the tree trunks in the directions of reception.
Yes you can install the antenna down low and see what reception is like.
Reason: Clarify Information and Typos.
