Old 12-Nov-2010, 7:46 AM   #3
whatsgoingonhere
Originally Posted by John Candle View Post
First , read and understand this , http://forum.tvfool.com/showthread.php?t=695 . Next , the group of transmitters are to the south and a little west. Do you have any windows or front patio or rear patio that is more or less in the direction the direction of the south west. Also for indoor antennas read and understand this http://forum.tvfool.com/showthread.php?t=233
Hi John,
Thanks for answering. The antenna is mounted on a pole outside the apartment. I pointed the bow elements (the scissor type things right?) are pointing south. I read somewhere that the Winegard HD 1080 is mainly a VHF antenna so I wanted to know if I should get a UHF antenna or just a different antenna to get more stations.
For example I get 47 but not 35 and from the plot I get the idea that 35 should be 'easier' to get.
Thanks for the help. I'm just putting bits and pieces of information together because I don't know much about this stuff.
whatsgoingonhere is offline   Reply With Quote
