Old 6-Nov-2013, 4:15 PM   #4
Pratical and Useful information.
WVNY-DT , REAL channel 13.1 , virtual number (22.1) , ABC .
Is being transmitted and received on REAL channel VHF high band channel 13 .
www.en.wikipedia.org/wiki/WVNY
To receive channel 13 , install a VHF high band channels 7 thru 13 antenna.
Install a Antennas Direct , C5 antenna.
The C5 antenna comes with a combiner to combine the C5 and DB4e antenna on to 1 coax.
Also install a Winegard , LNA-200 'Boost' XT , antenna system amplifier.
For 2 Tv connected use a , Holland Electronics , HFS-2D , 2 way splitter.
Buy the HFS splitters at , www.solidsignal.com .
Here is chimney antenna mount , www.ronard.com/ychim.html .
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
Separate the 2 antennas on the same mast by about 3 feet.
Put the DB4e below and the C5 above , on the same mast.
Aim both antennas at about 348 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Last edited by teleview; 6-Nov-2013 at 7:44 PM. Reason: Clarify information and typos.
