Old 5-Nov-2013, 11:49 PM   #2
Pratical and Useful Information.
Above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the direction of , South East .
Install a Channel Master CM4228HD antenna.
A antenna system amplifier will most likely not be required for 1 Tv connected.
A Winegard , DS3000 , J pole type antenna mount works Ok with the CM4228HD antenna.
Here are some more antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
Here are places to buy antennas and etc. .
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.winegarddirect.com
Digital tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear the tuner , Do Double Rescan.
www.wchstv.com/DoubleReSacnAlert.pdf
Last edited by teleview; 7-Nov-2013 at 5:13 PM. Reason: Clarify information and typos.
