Old 5-Nov-2013, 5:44 PM   #6
protivakid
You're on your own there. Assuming that the parts are interchangeable probably isn't a wise decision. For example, Winegard uses the identical plastic housing for its LNA100 amp and for the injector for the LNA200. The only physical difference is that one has an integral F-connector and the other has a short coax pigtail. I have no idea what Mohu is using for a power injector for the Sky as I haven't seen one yet.
I know it's not good practice but I am 99% sure that the two injectors are pretty much the same. Below are pics for comparison. I also would also bet that the Mohu Sky HD innards are VERY similar to the Winegard Flatwave Air.
protivakid is offline   Reply With Quote
