Old 5-Nov-2013, 4:41 PM   #5
Question though, since the mohu "power injector" is pretty much the same as the Winegard LNA-100, could I possibly still use one cable and pick up an LNA-200, putting the outdoor pre-amp with the VHF antenna, and having the power injector feed both that pre-amp and the one built into the mohu Sky? The "power insterter" that comes with the LNA-200 seems to be the same, I just don't know if it would be strong enough to feed both pre-amps.
You're on your own there. Assuming that the parts are interchangeable probably isn't a wise decision. For example, Winegard uses the identical plastic housing for its LNA100 amp and for the injector for the LNA200. The only physical difference is that one has an integral F-connector and the other has a short coax pigtail. I have no idea what Mohu is using for a power injector for the Sky as I haven't seen one yet.
