Old 5-Nov-2013, 3:03 AM   #3
Reception of a Fox affiliate is a challenge given that two stations, WFXT & WTIC are broadcasting on the same frequency, real CH-31.
You may want to explore alternate mounting height. A high gain antenna with a high F/B (front to back ratio) would also help. The Antennas Direct 91XG would be a top contender based on that criteria. Still, you could face the prospect of needing to take additional steps such as ganging two antennas to improve the F/B.
http://forum.tvfool.com/showthread.php?t=1024
