Thread: Hi everyone
Old 3-Nov-2013, 10:20 PM   #8
Pratical and Useful Information.
Home Depot and Lowes can have ANT751 antenna in stock in the store, no matter what the Home Depot and Lowes web sites say.
Here are other places to buy the ANT751 antenna.
www.solidsignal.com
www.amazon.com
Install the ANT751 antenna above the roof of the mobile home.
The ANT751antenna comes with a , J pole type antenna mount.
Install the ANT751 antenna at a location the has the least amount to no amount of obstructions of any type or kind in the directions of reception , North / North East and West.
Aim the antenna at about 25 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing.html
A antenna system amplifier is not required for reception with 1 or 2 Tv's connected.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations channels , often named the , DTV Channels ~ Air Channels ~ Antenna Channels , in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels.
Scan for channels.
Digital Tv Tuners can develop -Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 6-Nov-2013 at 5:26 AM. Reason: Clarify information and typos.
