Old 3-Nov-2013, 8:11 PM   #12
Ste4en
I'll wait then until i get a good reliable signal at least. I have moved the antenna around and up and down to try and improve Fox but i can't do any better...restricted to what I can mount it on. Seems like i will have to build something else. Do you have any advice on where best it would be located. maybe a dumb question but I have wood frame, roof boards, a few steel ties, air conditioning flex and solid ducting and beams and drywall ceilings below. Do i need to try for the most open area or the nearest place to the southern roof face (i am pointing the antenna to the south.
Ste4en is offline   Reply With Quote
