Pratical and Useful Information.
Disconnect and Remove and Discard ALL passive and active satellite system components such as and not limited to , multi-switches , multi-plexers , splitters , couplers , satellite receivers , amplifiers , power injectors , power supplies , and etc. .
Yes the satellite system coaxes and other coaxes that in/on the building can be used for the antenna system.
To test the coaxes and connections , use a , inline coax coupler , that is used to connect coaxes together to make the lengths of coaxes longer.
Use a known to be good continues length of coax as a test coax.
If the signal goes from the antenna to the Tv through the test coax but not through the coax that you think goes from point A to point B , Check the coax that you think goes from point A to point B.
You are using the continues length of coax as a test jumper.
Just because you think a coax goes from point A to point B , does not mean the the coax goes from point A to point B , or goes from point A to point B with no problems.
As near as I can tell , looking at the picture of the splitter it looks like a simple 2 way splitter and that is ok.
Reason: Clarify Information and Typos.
