Old 2-Nov-2013, 1:45 AM   #8
Ste4en
I bought and installed a Winegard HD7694P. connecting locally to one TV works great, I am getting all of the local channels with a rough direction setting, I will trim it later.
So I disconnected the cable that connects the Direct TV to the basement for distribution around the house and connected the antenna to it. So I think I should have the OTA signal in the basement. However using a Sv-2g 2-way Splitter 5-1000mhz I found, nothing seems to get that signal back up to the TV that worked in the first place. Do I need a special splitter to do this. The splitter i am using is : http://www.amazon.com/Sv-2g-2-way-Sp.../dp/B003TH36CK
I also have a channelmaster amplifier 0747 if that would help.
Any help appreciated.
Thanks
Ste4en is offline   Reply With Quote
