Is there a possibility of either of the following options?
Option 1 - Could a PC be installed in a central location and then distribute signal to all TV’s via MoCA adapters? Is the PC able to send out all receivable channels at once?
Option 2 – Could multiple Notch Filters be used to block out the competing signals on each array? The antennas pointing towards Boston/Manchester have filters that block out the signals from Portland and vice-versa for the antennas pointed towards Portland?
