Pratical and Useful Information.
1 to 1.5 dB is not that important for VHF low band reception.
The average consumer is not interested in jumping through hoop after hoop to get reception.
If you can recommend a consumer grade or even a professional grade low band antenna that does not cost big dollars , then recommend it.
Yes I am aware of the Big Winegard VHF low/VHF high band HD5030 antenna that is discontinued.
The HD5030 has less antenna gain at channel 5 , then the HD7084P antenna at channel 5 .
Reason: Clarify information and typos.
