Old 31-Oct-2013, 7:20 PM   #7
Practical and Useful Information.
The current receivable channels are all in the VHF band.
And no current receivable channels in the UHF band channels 14 thru 51.
WDTV-DT , Real VHF low band channel 5 , virtual number (5.1) , CBS.
WBOY-DT, Real VHF high band channel 12.1-2 , virtual number (12.1-2) , NBC and ABC.
WVFX-DT , Real VHF high band channel 10.1-2 , virtual number (46.1-2) , FOX and CW.
Install a big high gain antenna with high antenna gain of the VHF band channels.
Install a Winegard HD7084P antenna aimed at about 96 degree magnetic compass direction.
Install the Antennas Direct PA-18 preamplifier.
Going higher then 35 feet above ground does not provide a signeficant increase in signal strength.
Install the antenna at about 25 feet above ground.
Here are some strong and sturdy antenna mounts.
www.ronard.com/909011.html
Install the , ronard(911) , 5 foot tripod antenna mount.
www.ronard.com/Tripods%200703/4712.html
10 foot tripod antenna mount.
www.ronard.com/34424560.html
Install the , ronard(4560) , eave antenna mount.
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or by from , www.ronard.com .
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
www.ronard.com
Buy the HFS splitters at , www.solidsignal.com
Last edited by teleview; 31-Oct-2013 at 7:29 PM. Reason: Clarify information and typos.
