Thread: Lightning Fix
Old 11-Nov-2010, 8:12 PM   #14
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
I have a 2-story house with the antenna on top (obviously).
There is no single point earth ground within single digit feet.
So, if I used a single coax line grounding block like below, it would have to be mounted somewhere inside the house so that I could tie into a single point earth ground (like a copper pipe).
There are vents from the bathrooms & kitchens that come up through the roof, but the bedrooms & kitchen are on one side of the house; the living room is on the opposite side and certainly not within single digit feet.
Where does that leave me?
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
