Old 31-Oct-2013, 5:34 PM   #2
It's quite likely that with weak TV signal levels, you'll find other radio services will be blocked by the same terrain. If that's true, you have less interference to contend with.
So, a big antenna with VHF capability would be your best hope. Consider the Winegard HD7084P + Antennas Direct PA-18 preamplifier.
