Practical and Useful Information.
Install the SS1000 or any other antenna above the peak of the roof in such a manner that the roof and building are not , obstructing , impeding , blocking reception in the directions of reception.
As Always, trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception.
Absorbing and Blocking reception
Multi-path reflecting Tv signals bouncing around
The Best Pratice is to install a Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
As has been stated , the CM7777 is to high of gain amplification for your location , the Tv signals reception is very strong at your location.
The amplifier can over load from the strong signal strengths and make reception worse.
Please locate the SS1000 antenna or any other antenna to a better reception location.
And correct wiring problems.
Reason: Clarify information and typos.
