Old 30-Oct-2013, 2:47 AM   #6
Pratical and Useful Information.
Above the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North East and West , Install a Antennas Direct C5 VHF high band channels 7 thru 13 antenna aimed at about 40 degree magnetic compass direction.
The C5 comes with a VHF/UHF combiner to combine the C5 VHF high band antenna and HDB8x UHF band antennas on to one coax.
Install the HDB8x antenna above the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North East , West , South West.
Aim the HDB8x antenna at about 225 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antennas.
Install a Channel Master CM7778 preamp to the output of the combiner so that both antennas are amplified.
Buy the HFS splitters at , www.solidsignal.com .
www.ronard.com/909911.html
Use the , ronard(911) , tripod antenna mount.
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) in the solidsignal search box , or , buy from , www.ronard.com :
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.ronard.com
Last edited by teleview; 4-Nov-2013 at 6:26 AM. Reason: Clarify information and typos.
