Extremely Helpful
Thanks teleview for all of the information I needed. I am nearly ready to put everything up but I am left with one more question I hope somebody can answer. Knowing that both the coax and antenna mast must be grounded what is the best way to go about it. I have seen Coax with ground wire together on the same cable in a few stores. Would that work or should/must I keep the coax and ground wires on separate cables.
