Old 29-Oct-2013, 8:37 PM   #14
Practical and Useful Information.
So as to reduce reception and distribution problems.
Disconnect and Remove and Discard All satellite passive and active components such as and not limited to , multi-switches , multi-plexers , splitters , couplers , amplifiers , power injectors , power supplies, and etc. .
Yes the satellite system coaxes and other coaxes that are in/on the building can be used for the antenna system.
The Winegard DS3000 , J pole type antenna mount works Ok as a mount for the CM4228HD antenna.
Here are some more antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.winegarddirect.com
www.ronard.com
Last edited by teleview; 29-Oct-2013 at 8:47 PM. Reason: Clarify Information and typos.
