Hello fellow TV Foolers-
I'm a new Fooler and new to OTA.  I recently purchased a HDB8X from Solid Signal (based on Mr Higgins testing) and installed it in my attic with decent results.  I'm hoping with a little advice and tweaking I may be able to get some stations that I am currently unable to get.
http://www.tvfool.com/?option=com_wr...46ae5e8da9e7b1
Currently I have the antenna pointed at 190ish degrees Azimuth in my attic with both panels set parallel.  I am able to recieve 19 and 20 (as well as a handful of stations broadcasting from other directions) but I am specifically hoping to get 30 and 31 (it is the World Series and I'm in Sox territory...)
  I am not particularaly interested in non-UHF stations or stations in other directions.
The sight lines at 190 are pretty clear in my yard but there are some trees 500 or so yards out.  I also am using a 100' coaxial cable currently for testing (I know it has some inherent loss although I don't know how much) which I plan to shorten once I find the final resting place.
Strangely I tried putting the antenna out a 2nd story south facing window pointing at 190 and had much worse reception (fewer channels) than in the attic.  There was probably 8' less in elevation and anything coming into the back of the antenna was blocked by the house.
I would imagine outside above the roof should be better although I'd leave it in the attic if I can squeeze a couple of DBs out of a preamp.
Thanks in advance for any advice,
J
