Old 29-Oct-2013, 1:32 PM   #14
PeteyMcp
GUM,
That Pre-amp that you recommended is significantly cheaper than the previous one I purchased and seems cheaper than most of the pre-amps I see out there. I can get it for $24 delivered, I may just give it a shot since it's so cheap. What is the chance that I overpower some of the stronger signals? I can occasionally get NBC to come in right now with a signal of 35-40, which seems to be the minimum I need to get a picture, I'm hoping a working pre-amp might get me a solid signal, at least through the winter.
Brian
PeteyMcp is offline   Reply With Quote
