If you exhaust all options with the SS-1000, and need to switch to a different antenna...
I would still want to recommend you step up the UHF performance relative to the SS-1000. The following will all have improved UHF and H-VHF capability but lack the wide elements for L-VHF.
Channel Master's CM-2020
Antennacraft HBU-33 and larger
Winegard HD-7694P
Antennas Direct CS2 or CS4 or DB2e or DB4e + CS5 or (Antennacraft Y5713 + UVSJ)
Perhaps from an esthetics perspective, the combination of a CS2 & CS5 would be the smallest foot print.
