Old 29-Oct-2013, 7:08 AM   #7
tjsully21
GroundUrMast,
I tested a couple different locations with and without the CM-7777. It improved signal strength on several channels, on the rest it didn't make much difference. I also did the Basic A-B-C test with the shortest run. There the amp made little difference.
I took a look at the antennas you mentioned - Antennacraft HD1200 and Channel Master CM-3018. I'm sure either would suffice, but I have serious doubts that the wife will agree to a 9 foot antenna on the roof. Any suggestions for one with a smaller footprint that you think might work?
If I end up needing a distribution amp, so I'll probably go with the CM-3410 like you suggested.
Thanks again.
tjsully21 is offline   Reply With Quote
