Your main stations are ALL located in Bithlo, unless you want to chase some of the off-the-wall LP stations, there's no point in aiming the antenna anywhere else.
Go look at your roofing material what's it made of? Metal or tile? Is there radiant barrier insulation installed?
Going outside and facing towards Bithlo, what does it look like? Larger buildings or trees in the signal path?
Most likely, you'll have to get the antenna out of the attic since such locations are too often unpredictable hellholes for reception.
