Pratical and Useful Information.
The CM4228HD does not have "dicey" VHF supprot.
The VHF reception is Ok.
The CM4228HD antenna is designed to receive UHF channels 14 thru 51 and VHF channels 7 thru 13.
The 2 VHF high band channels to receive are
WHEC-TV channel 10 is 66.3 NM (dB) very strong signal strength and is 5.5 miles away and is LOS=Line of Sight.
WHAM-TV channel 13 is , 65.5 NM (dB) very strong signal strength and is 5.5 miles away and is LOS= Line of Sight.
These Tv stations will easily be received by the CM4228HD antenna.
Reason: Clarify information and typos.
