To receive the weak signal from RCH-29, you need to step up to a larger antenna or combination.
The Winegard HD-7698P is not overkill. The combination of an Antennas Direct DB8e + Antennacraft Y10713 would not be overkill either.
Can you post the amplifier make /model?
