Old 28-Oct-2013, 2:17 PM   #1
jono06
Help getting channel
Hi everyone, I need some advice to determine why I am not getting a particular channel with my antenna setup. I have an RCA ANT751 mounted on the roof using a mount previously used for a satellite. The cable runs into an amplifier (don't have the model number currently, but can get it later) straight down from the antenna - around 25 feet - and then the cable runs directly to the TV - probably another 50 or so feet. Without the amplifier I got channels 11 (CBS) and 39 (Fox), but the quality wasn't very good. With the amplifier, I now get channels 11 and 39 with good signal and also 19 (ABC). The problem is that channel 5 (NBC) doesn't come in at all. It seems like it should be the easiest channel to receive according to my signal analysis. Also, I didn't get signal for 5 prior to using the amplifier, so I don't think it's causing the signal to be too strong.
Any ideas or recommendations would be greatly appreciated! Thanks!
http://www.tvfool.com/?option=com_wr...46ae9ed822a9c7
jono06 is offline   Reply With Quote
