Old 28-Oct-2013, 3:54 AM   #22
Originally Posted by Jwwann View Post
Hooked up amp today and lost everything. Took it off and everything is back. Could I have received a bad amp?
It's possible the amp is DOA...
Was there a splitter or any other accessory between the power supply and mast mounted unit?
Did you verify the position of the separate/combined switch and make certain the FM trap is on?
