Old 27-Oct-2013, 6:51 PM   #1
B34N
What will I need for reliable reception?
Before moving to my current home I used an attic mount antenna with great results. Now I'm just five miles away and it seems that getting a good reliable signal will be much more difficult.
Here is my TV fool report.
The channels I most care about are all in the same direction of 227 degrees. The few PBS channels not at 227 and in the green or yellow categories would be nice to have but I wouldn't want to have to install any costly equipment for them. Anything outside of the red category is not at all important to me.
I live in a two story single family home. I am at a lower elevation than most of the other homes around be but fortunately there are no buildings blocking the direction that I need. I've been trying to download the Google Earth maps for Philadelphia but there are no peers to connect with.
I plan on using the existing coax installed in the home when it was built in 2001. The junction box/splitters are in the basement. I will be using up to three TVs (all with ATSC tuners) and two to three capture devices.
  1. Will I get good results with a roof mounted antenna?
  2. Could I get good results with an attic mount instead?
  3. Approximately how much should I budget if DIY or professionally installed?
Thank you,
B34N
B34N is offline   Reply With Quote
