Old 26-Oct-2013, 6:06 PM   #5
Pratical and Useful Information.
The Current Broadcast Tv stations/channels that are being Transmitted and Received in the , USA , Canada , Mexico , are
UHF band channels 14 thru 51.
Your location has receivable broadcast Tv stations channels in All 3 Tv bands.
To the East /North East is
KVNV Real channel 3.
WPXO-LD Real channel 4.
WKOB Real channel 2.
Recommend install a Tv antenna that receives All 3 Broadcast Tv Bands.
The HD7084P antenna also provides the extra antenna gain to receive the VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
Install a Winegard HD7084P antenna aimed at about 80 degrees magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
The HD7084P antenna receives All 3 Tv bands better then the HD8200U antenna.
And HD7084P antenna is smaller then the HD8200U antenna.
The reason the HD7084P receives better is because the HD7084P has more metal receiving elements in a more compact space , is provides a flatter response across all the Tv channels.
Last edited by teleview; 27-Oct-2013 at 5:01 PM. Reason: Clarify information and typos.
