Old 10-Nov-2010, 6:17 PM   #2
I would try a basic (inexpensive) set top antenna with no amplifier (built-in or external). (http://www.solidsignal.com/pview.asp...or%20Only&sku=) is an example. If you are still using an analog tuner/TV, expect ghosting and other interference. If you have a DTV capable tuner or converter, I expect that you will be amazed at the quality of the picture on CH. 38 PBS. As Canada switches to DTV, expect the quality of the pictures on all channels to improve dramatically.
