Old 26-Oct-2013, 2:53 PM   #2
Do I have the correct antenna?
No, but perhaps half of the correct system.
Should I have gotten the Winegard HD8200U instead?
Goodness, no, although it *could* be used. You just don't need all that excess aluminum for low-VHF up in the air.
The glaring problem is that you have a UHF antenna and are expecting it to pick up weak high-VHF signals. 8-bay UHF antennas often pick up high-VHF at very odd angles since they are not engineered for VHF reception.
The simplest solution is to add a high-VHF antenna to the 8-bay UHF antenna. Otherwise, start over with a medium to long range high-VHF combo.
Pick your pre-amp with care. Your proximity to your local channel 8 will put some pre-amps into gain compression.
