Old 26-Oct-2013, 2:17 PM   #1
jrmbps
Channel Reception.
This is my location map: http://www.tvfool.com/?option=com_wr...46ae689b8f4f4c
I have recently installed a Solid Signal 8-blade HDB8X antenna with pre-amp, rotor, amp, and all the recommended wiring and fittings.
When the antenna is set to ENE, on a HDTV, I am able to receive a great signal on channels 2 through 5, but ch.7 needs to be tweaked via the rotor in order to get it clearly with some occasional signal loss. In order to get ch. 13 at the ENE setting, I have to go through the TV's auto-tuning process. I'm sure there must be a simpler solution.
The installed antenna is currently set flat. Should the bays be angled? Do I have the correct antenna? Should I have gotten the Winegard HD8200U instead?
Any help or advice would be appreciated. Thanks.
jrmbps is offline   Reply With Quote
