Pratical and Useful Infprmation.
Of the type and kind of antennas such as a CM5016.
The smaller CM5016 receives more at the front of antenna then the C2v antenna.
The CM5016 is less directional because it is smaller , being less directional in the forward direction , the CM5016 receives better at angles to the antenna.
The Winegard HD7084P antenna is a type and kind of antenna as the CM5016 antenna.
For more reception in the forward direction , install a big antenna , install a Winegard HD7084P antenna aimed at the 300 ~ 304 direction.
Reason: Clarify information and typos.
