Gum, the coax coming out of sat dish is double strand with what appears to be a ground wire too. So do I run coax out of antenna, into amp, out of amp, into two way splitter for the double coax of sat which runs into single coax in my living room? Or just run into one side of coax from sat? I hope this makes sense. The module on the dish had two hookups and stayed double stranded I guess for two different satellites. When it comes out inside house it single. Do I need to crawl under house and look for where it splits or will it even make a difference?
