Old 25-Oct-2013, 11:41 AM   #6
dm6789
I decided not to try fooling around with a small antenna. Mounted a Winegard HD9095P on the roof. This setup works well when connected to one TV for all the channels that are at 174 degrees. I plan to keep it fixed with no rotor. The toughest channel that I care about getting is WFXT-DT (31).
I'd like to connect the antenna to 2 TV's. Here's the setup: 60 feet of RG6 to the 1st TV, 2-way splitter, approx 100ft of cable to the 2nd TV. With this in place, the 2nd TV doesn't pick up WFXT and it becomes iffy on the 1st TV. I assume a preamp should be installed. Signal strength for this channel is around 50% at the 1st TV. Most of the other channels show signal strength around 90%. Is a high gain preamp, say around 29dB UHF, likely to overpower the tuner on the stronger channels? Anyhow, I'd like to get preamp recommendations from the experts here.
dm6789 is offline   Reply With Quote
