Old 24-Oct-2013, 11:27 PM   #5
Pratical and Useful Information.
Siganal strengths are improved at 25 feet above ground.
Install a Channel Master CM5016 antenna above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , north , north west , west , south west , south east , east , north east.
Aim the CM5016 antenna at about 265 degree magnetic compass direction.
Here is how to a antennas , www.kyes.com/antenna/pointing/pointing.html
Install a Channel Master CM7778 preamp.
Buy the HFS splitters at , www.solidsignal.com .
www.ronard.com/909911.html
Use the , ronard(911) , 5 foot tripod antenna mount .
www.ronard.com/34424560.html
Use the , ronard(4560) , eave antenna mount .
www.ronard.com/ychim.html
Buy the ronard antenna mounts at solidsignal by typing , ronard(x) , I the solidsignal search box or buy from ronard.
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.ronard.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception
Absorbing , Blocking , Tv reception
Multi-path Reflections bouncing all around
And buildings and other obstructions including your own roof and building.
The Best Pratice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , DTV channels ~ Air Channels ~ Antenna Channels , in the Tv Setup Menu because the Tv transmissions travel through the Air from transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels.
Scan for channels.
