Old 24-Oct-2013, 9:01 PM   #5
stonesif
Thanks. I am using the built-in tuner on my 720HD TV. It allows me to manually go through to specific digital channels like 7.1 or 44.3 in the setup menu to see signal strength. I can check and confirm in the manual though if it has an ATSC tuner, but I believe it should. And I am checking via the antenna input and not through cable.
Good tip ADTech. I'll try that out next!
stonesif is offline   Reply With Quote
