Thread: Antenna Help
Old 24-Oct-2013, 8:32 PM   #5
Paritcal and Useful Information.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception
Absorbing , Blocking , Broadcast Tv reception
Multi-path reflections signals bouncing off the trees and tree leaves , plants and plant leaves
Moving multi-path because of the wind , moving multi-path is Very Bad for Digital Broadcast Tv Reception.
The Digital Broadcast Tv Tuners computer can correct multi-path up to certain point and then the computer is over loaded and picture and sound Will Be Bad.
Buildings and other obstructions including your own roof and building will also disrupt reception.
The Best Pratice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind , including trees and tree leaves , plants and plant leaves and buildings and other obstructions in the directions of reception including your own roof and house.
