Old 24-Oct-2013, 3:42 PM   #1
killroy
How Can i improve reception
Like most of us on these forums i recently cut the cord and am looking for some help.I believe this is where i can get it. Here is my current set Up:
http://www.tvfool.com/?option=com_wr...46ae107a6f368f
I have the clear stream2 antenna mounted about 30 feet up
The antenna is pointed roughly at 300-304 degrees where most the local network towers are.
When I ran the channel scan on my HDTV it picked up like 85 channels which was dam impressive.
However, vhf band ABC (7), and KCAL (9) which are located on same mountain are not coming in but my TV seems to know they are there or it would have never memorized them and i did have both for a short time.
My questions are these:
Would an amp help? If so which one? (preamp?, distribution amp? recommended models)
Would moving the antenna help?
Or do I need a different antenna all together? if so which one?
Thank you,
curious in California
killroy is offline   Reply With Quote
