Thread: Antenna Help
Old 24-Oct-2013, 3:23 PM   #2
Practical and Useful information.
Remove ->All<- of the twin lead antenna wire every where through out the system both outside and inside of the building.
Only use RG-6 coax to do antenna system wiring.
Use passive and active devices that connect to RG-6 coax.
Install a NEW Matching Transformer (Balun) that connects the New RG-6 coax to the antenna.
Aim the antenna at about 80 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Digital Tv Tuners can develop -Digital Glitches-that are not cleared out with simple channel scans.
Do Double Rescan , www.wchstv.com/DoubleReScanAlert.pdf
