Old 24-Oct-2013, 2:09 PM   #4
You should be able to pick up a dozen or more local stations with nothing more than a straightened paper clip inserted into the coax connector of your TV set, the signals are so strong. Try one of those first as you go through the TV set programming. If it works, switch back to your "Youtube defect" antenna and try again. You might have a bad coax or matching transformer.
