Old 24-Oct-2013, 11:18 AM   #3
Stereocraig
Originally Posted by PeteyMcp View Post
And I should point out that I normally have pretty strong signal strengths on all of these.
Process of elimination, is the way to go.
Start by removing the preamp and injector and proceed to remove splitters and additional TVs and coax runs.
It may be a long shot, but also check that there is no continuity between any of the driven elements and the boom/ mast.
I have a 7698p and it had a dangling chad that was making contact w/ the rivet all the way in the rear that connects the two phasing lines together.
I had to drill it out and ream the hole bigger and replace it w/ a bolt.
