Old 24-Oct-2013, 6:33 AM   #3
As teleview has indicated, your tuner must be capable of receiving ATSC aka 8VSB. Older televisions (pre-2007) are not likely to have that capability. If you have an older TV you can likely find a copy of the user manual online to verify if it does or does not have a digital over-the-air (ATSC/8VSB) capable tuner.
Set top converters are available if you need to keep an older TV.
Cable systems use a different digital modulation format, QAM which is incompatible with the OTA signal format. (Which is why you need to set the tuner to the correct signal format.)
