Old 23-Oct-2013, 6:03 AM   #3
Pratical and Useful Information.
The Digital Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels in the Digital Tv Setup Menu , often named the , DTV Channels ~ Air Channels ~ Antenna Channels , in the Digital Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Also Do Not channel scan for only Analog Broadcast Tv channels.
Go into the Tv Setup Menu and select , DTV Channels ~ Air Channels ~ Antenna Channels.
The Tv reception is Strong Signal Strength at your location.
Even with the obstruction , several Digital Broadcast Tv stations/channels should be received with indoor antenna.
For a outdoor type antenna use a ANT751 antenna aimed at about 250 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Receive the Digital Broadcast Tv stations/channels.
Known as the ATSC Broadcast Tv Channels , aka , 8VSB Digital Tv signal.
What are Make and Model Numbers of the Tv/s??
Last edited by teleview; 23-Oct-2013 at 7:08 AM. Reason: Clarify information and typos.
