Old 22-Oct-2013, 8:20 PM   #1
RhinoRunnin
Any better setup for what I have?
Hi, Being new to OTA after cutting cable, I 'm realizing you are at the mercy of many variables when it comes to getting a good reception unless your lucky enough to live fairly close to the signals; there are no magic bullet, so equipment wise am I at the best I can get for best reception?
Being at http://www.tvfool.com/?option=com_wr...46aeffe49731a4
with an AD 91XG & RCA TVPREAMP1R, 50' RG6 cable on 20' pole, I'm getting OK reception at times & terrible at other times depending on time of day & weather.
Since I have a UHF only antenna now & there are 2 Hi VHF stations I like to get (ABC & NBC), should I get a VHF only antenna (like a Winegard YA-1713 VHF high-band) to combine w/ the 91XG or get Denny's HD Stacker (only because it's reasonably sized & not a super long 14 footer like Winegard HD 7698P)
And get a better preamp with more gain? I don't know if any other preamp would be better than the RCA TVPREAMP1R on weak signals.
Thank you for your input!
RhinoRunnin is offline   Reply With Quote
